Old 16-May-2006, 22:03   #2
Making a Marchesini fit? Have you tried taking it for a long run...fnarrr, fnarr...
I'm not convinced about the sleeve idea, much better get a set of bearings to suit the smaller axle or converting your swingarm to take the larger axle.
Don't think the wheel came off an ST2 since Marchi's are only standard on an ST4S - although I think it will fit an ST2 as a straightforward bolt in, but is the conical spacer included? That might sort out the 2mm clearance...or then again it might not.
Tell you what...I need a new rear wheel for my ST, so give me a shout if you can't make it fit
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:37.
