Old 23-May-2006, 08:03   #11
loony888 loony888 is offline
Mood: sensational!!
Originally posted by Mr. R
Hi, surely you meant 3 bar for the pump? pressure reg' is set to that as standard on strada's and 4.5 bar on sps's.
I think the pump is capable of pumping 5 bar,as fitted to these dukes.
Steve
the pump is capable but according to pete smith from epicycle you should not run pressure higher than 450kpa as the pump temperature rises to dangerously high levels. if you need more pressure than that you need a corsa pump.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:06.
