Old 04-Jun-2006, 12:33   #10
Roy748Bip Roy748Bip is offline
Mood: skint.....
Originally Posted by bolds
Because the later type slave cylinder is a sealed unit when it is not in position the lever will be solid as the fluid will pressure the piston to the end of the cylinder
to check that side is working remove the clutch pressure plate and get someone to push the pushrod with a block of wood etc and then try the lever while they are forcing the pushrod.
I still think your problem is too shorter pushrod fitted
I think that's the problem as can push the piston back and it works ok until it hits the end of the bore. Cheers. I need to get a longer rod now whick is a problem as my local dealer just went under.......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:57.
