Old 14-Jun-2006, 18:52   #1
9rrr 9rrr is offline
Thumbs up Home made Clutch tool.
Help please guys. I have a 996r with a Bucci slipper.
I want to grease the ball ramp at the rear of the clutch housing so I made a tool out of my old clutch plates.
When fitting the tool after I ve removed the plates it goes in but the nut Iam attempting to remove keeps spinning round
Is this because the clutch tool isnt far enough in to reach the back surface, Quick responce please as I need to get the old girl back together.Thanks Ian.
Old 14-Jun-2006, 18:57   #2
razz razz is offline
Stupid question maybe, but did you make your tool out of old friction plates or old plain steel plates? You have to use old steel plates so that the clutch centre is held, not the outer basket.
Old 14-Jun-2006, 19:14   #3
DAAAH!!!. You are right. What a +ick.
Thanks very much razz.
Old 14-Jun-2006, 20:08   #4
Old 14-Jun-2006, 20:34   #5
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
You want a mixture of both plates, this will lock the clutch solid if you position with so that the handle (if one fitted) rest on the foot peg.
Old 14-Jun-2006, 20:38   #6
Would I get away with tack welding a steel clutch plate onto the existing tool.
Otherwise I am going to have to source some old plates and start again.
Old 14-Jun-2006, 20:42   #7
Jon Jon is offline
Jon's Avatar
The only problem with that is all the pressure will be excerted on one spot. Seeing that the hub center is ergal and the pressure of the steel plate could damage you drum.
Old 14-Jun-2006, 20:49   #8
pedro pedro is offline
pedro's Avatar
Mood: r
i would recomend the ones for sale on ebay,around £50-£60. only buy it once.
Old 14-Jun-2006, 21:17   #9
No probs. Thanks guys.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:36.
