Old 17-Jul-2006, 06:50   #10
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
Steve, notice your running a BT010 on the front, is it a 120 ? reason i ask is the RC wears a 3" rim as standard. Keep an eye out for a NC30 wheel which bolts straight in and is 3.5"
Mine feels like its tearing the 010 now its half worn making the front feel not quite so planted, however i have used a maxton ride height converter to allow for the 17" rear but still running the standard ride height and its rather conservative steering angle.
Also as i am sure you will know - keep an eye on that oil level, always at the top or above maximum.
If yours is running a tad on the warm side (like they do in this weather) try and source a new kill switch, mount it on the clutch master cyl, earth one of the wires and put the other to the fan switch located on the left of the top rad allowing you to manually switch the fans on if doing 30 in towns. doesnt cool it much but keep it from getting hotter.
HTH
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:18.
