Old 04-Aug-2006, 15:39   #1
DSC Member final_edition final_edition is offline
final_edition's Avatar
Mood: Having some tinnies and a barbie
Question JHP clutch slave cyl
I have fitted a JHP clutch slave cyl to my '04 998s and I am having a few problems with it.
What I've noticed is that it is hard to get into neutral, when stopping at lights etc. When changing down, the gears feel notchy as if the clutch isn't fully dis-engaging. If I have the bike on the paddock-stand and select 1st gear while the engine is running, when I pull the lever in the back wheel still spins and will only stop with the back brake applied. If the brake is released the wheel will spin again.
I've read other threads with regard to rod length (oeer missus) but I thought having a later bike mine should be ok.
I've bled the system correctly.
Any ideas?
FE
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:47.
