Old 12-Sep-2006, 15:46   #1
steve bid steve bid is offline
Mood: 748r god what a sight drool droo
1995 senna
did they make a senna in 1995 didnt think so but i could be wrong
Old 12-Sep-2006, 15:49   #2
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
That would have been one of the first (grey ones)..which was replaced in 96 by the silver Mk2
Nat
Old 12-Sep-2006, 15:50   #3
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
no without a dout.
Old 12-Sep-2006, 15:55   #4
Nattyboy's Avatar
At the risk of sounding like a smart arse chass..YOUR WRONGGGGGGGGGGGGGGGGGGGG!!! lol !
There were roughly 300 sennas knocked up in 95
Old 12-Sep-2006, 18:16   #5
Bikes: 916 Strada
Chaz's Avatar
Wink
You may be correct about grey imports but the book I have say's they were not imported to these shores until 96, I don't claim to be an expert but I bought my first 748 in 96 & waited ages for it had it on order from mid 95 & there was very few 916 or 748 about.
Old 12-Sep-2006, 18:25   #6
Check this web site
http://www.916ducati.co.uk/
Click 916 picture to enter, then
click on the Senna 916 bar on the left hand menu
Chris.
Old 12-Sep-2006, 18:26   #7
916 SENNA GENERAL INFORMATION
Year Produced 1995-99
ENGINE/TRANSMISSION
Displacement, c.c.: 916.00 ccm (55.89 cubic inches)
Engine type: 90 degree V-2 or V-TWIN four stroke
Stroke: 66 mm
Bore: 94 mm
Compression ratio: 1:11
HP (kW): Horse Power 105.00 (77.2) @ 9000
Torque - Nm (kgf-m / ft.lbs): 90.00 (9.2 / 66.4) @ 7000
Max r.p.m: 10,000 r.p.m.
Valves per cylinder: 4. Desmodronic
Cooling system: Liquid
Gears: 6
Final drive: Chain/DID Type/525HV Links/94
Starter system / ignition: Electronic/Fuel Injection
CHASSIS/DIMENSIONS
Front brake(s): Dual disc drilled/cast iron fully floating 320mm. Brembo Calipers
Rear brake: Single disc 220mm. Brembo Caliper
Front Wheel: Brembo 3.50x17 Alloy 3 spoke
Rear Wheel: Brembo 5.50x17 Alloy 3 spoke
Front Tyre: Tubeless, radial 120/70-ZR17
Rear Tyre: Tubeless, radial 190/50-ZR17
Rear Suspension: Ohlins type DU 3420
Front Suspension: Showa GD051 Stanchion dia. 43mm
Overall chassis length: 2030mm
Overall chassis height: 1080mm
Chassis width to end of levers: 780mm
Rear Sub-frame Alloy
Seat height (lowest setting): 31.1 inches --- 790 mm
Weight (dry): 436.5 pounds --- 198.0 kg
SPEED/ACCELERATION
Top speed: 155.3 mph --- 250.0 km/h
Old 12-Sep-2006, 19:10   #8
Like this one by any chance
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250026780775
F
Old 12-Sep-2006, 19:23   #9
Here's a couple of '95 bikes.
Old 12-Sep-2006, 19:32   #10
Bikes: 916 Strada
Chaz's Avatar
Talking
Originally Posted by Iconic944ss
YEEEEEEEEEEEEEEER
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:29.
