Old 29-Nov-2006, 22:40   #1
9rrr 9rrr is offline
Quick action throttle.
Anyone using one of these. Are they any good.
Old 30-Nov-2006, 07:46   #2
khushy khushy is offline
khushy's Avatar
yep
I fitted one when I first got my bike - very good and fully adjustable - comes with 3 different cams!
Khushy
Old 30-Nov-2006, 09:43   #3
Simon Reed's Avatar
Mood: Cool as **** !
If using the 749/999,most people just fit a 996 oe one,as the ratio is like q action unit,in comparison,and cheaper !!!
Old 30-Nov-2006, 09:54   #4
khushy's Avatar
Wink from a safety perspective . . .
this is NOT a good idea as it only has one cable - the 749/999 has two - open and close is controlled by the cable and not by the return spring!
Khushy
Old 30-Nov-2006, 14:53   #5
testastretta testastretta is offline
testastretta's Avatar
Question
Khushy
Where did you get the beautiful grips with red cut-outs ? Been looking for these .
Old 30-Nov-2006, 14:56   #6
pedro pedro is offline
pedro's Avatar
Mood: r
ive seen the in motrax book,only around £6
Old 30-Nov-2006, 15:15   #7
pedro's Avatar
Mood: r
heres mine,i got me a 996 throttle twist grip then bin the 996 cable as its too short,then with your 999 cable -i took it to a local cable maker who replaced the inner cable while threading the metal 996 housing adjuster,you want to retain the 999 cable as the outer cable has a plastic coat inside which make for a smooth action. i know of lots of 999s thet have had this done without any spring problems. failing that pro v twins can sort you a rs cable to replace the 999 cable for around £70-£90?. my rework cable set me back £10.
Old 30-Nov-2006, 15:38   #8
khushy's Avatar
I got em from . . .
Riders of Bridgwater - £10 I think!
Khushy
Old 30-Nov-2006, 15:40   #9
khushy's Avatar
Pro Twins wanted £200 for their mod - they said that they had to modify the spring - RUBBISH.
Either mod works fine WITHOUT a spring mod!
Khushy
Old 30-Nov-2006, 16:09   #10
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
i've used a 999 and the throttle is to light and has too much travel, the single cable one was much better. And they still fit a single cable to the s4rs so carn't be too much wrong with it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:31.
