Old 30-Nov-2006, 15:15   #10
pedro pedro is offline
pedro's Avatar
Mood: r
heres mine,i got me a 996 throttle twist grip then bin the 996 cable as its too short,then with your 999 cable -i took it to a local cable maker who replaced the inner cable while threading the metal 996 housing adjuster,you want to retain the 999 cable as the outer cable has a plastic coat inside which make for a smooth action. i know of lots of 999s thet have had this done without any spring problems. failing that pro v twins can sort you a rs cable to replace the 999 cable for around £70-£90?. my rework cable set me back £10.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:34.
