Old 07-Jun-2003, 17:48   #16
rcgbob44's Avatar
Rear Wheel Torque Settings
I hope this helps:
Rear wheel nut should be torqued to 176 Nm, this equates to 129.8 ft lb`s. I have attached the ducati tech spec sheets detailing this, if you need to convert the other settings you can get the conversion bits from the web. Good luck
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:16.
