Old 17-Mar-2004, 14:01   #1
Multi Rod Multi Rod is offline
Multistrada Soft Panniers.
I see that Ducati make soft panniers for the Multistrada, has anyone purchased these??
Comments......
[Edited on 17-3-2004 by Multi Rod]
Old 17-Mar-2004, 14:50   #2
Blat182 Blat182 is offline
Mates have bought them and really rate them, even 2 up. But neither of them fitted them to a 9XX or multistrada. I'm not sure how you would get the straps to fit with the underseat zorsts though. I understand that bit was quite tricky.
This post probably doesnt help does it!
Ian
Old 17-Mar-2004, 17:07   #3
I should have been more specific, I am only interested in the Ducati soft panniers made specially for the Multistrada.
Old 17-Mar-2004, 17:11   #4
luckywhiteheather luckywhiteheather is offline
Mood: Electrically challenged
Multi Rod, do you mean the DP ones specifically for MS or just soft bags in general?
I know DP ones fit on a set of brackets/frame similar to, if not same as, that for 'hard shell' panniers so no problem interfering with exhausts Ian.
I've got hard shell ones with which I also have the nylon internal lining bags. All-in-all pretty well made stuff and I'm sure soft panniers will be likewise.
Check out www.multistrada.net web-site as loads of guys on there have even used other after-market kit.
Cheers!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:31.
