Old 20-Mar-2004, 00:48   #3
The thin brown body gaskets do get a bit crushed out of shape but providing they are intact should be Ok.
I think its more important to be careful with the rubber type diphragms under the rounded top of the carbs that can be easily damaged.
Erm...other bits to look for:
The main slide, should do just that, slide smoothly in the bore.
The big needle should have a smooth profile and a sharp tip.
No blockages in any jets.
The plastic float assembly should all move easily - be careful around here as well.
I think I still have an unused stage 1 Dynojet kit laying around somewhere if its of any use
Good luck - Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:50.
