Old 20-Mar-2004, 07:23   #6
If the fuel pump is working and the starter motor turning it may just be that your starting tecnique is at fault.Is the engine kill switch on?Bike in neutral?
Switch on the ignition and let the instruments do their light show.Press the starter button.DO NOT use any throttle or cold start lever.When (if!) the bike fire's up use the cold start lever to control the revs.
If the bikes imobilser is working,the EOBD light will be on and the starter button will do nothing.You can disable it with the red key and code.
[Edited on 20-3-2004 by KeefyB]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:47.
