Old 06-May-2008, 17:19   #25
chillo chillo is offline
chillo's Avatar
Originally Posted by RIIIKYL
Hi guys - the good news is that my 999R running problem was apparently a fuelling issue with it suddenly running extremely rich !!
(like a pile of s**t !)
Hats off to the boys at 3X Mcycles - they fixed it and it runs fine now !
It also had to have the safety recall check on the oil cooler ! - if you've got one with a KTM cooler - make sure you get it checked !!
Bit of a thread revial!
Just got what i think is a coil issue (1 cylinder ecu light) and also spotted this in the middle of this thread whilst searching... Do you know what 3x did to your bike to cure the fuelling?
Mine has been serviced (inc new fuel filter, old one virtually blocked!) and has not been running well since!
Bike has PC and the guess is that there is too much fuel getting through now!?
Race ecu faulty (variable rev limit/power) so was set up with standard ecu. Currently running with PC taken off and race ecu put in.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:43.
