Old 14-Jan-2009, 21:16   #51
Matt-T28 Matt-T28 is offline
Matt-T28's Avatar
Mood: 2008 Desmodue Class B champion
Originally Posted by vespa
So balancing actually reduces the chances of engine failure. You don't need to do it but once you open you engine it would be daft not to do it, as long as you keep within the factory weight tolerance limit. An alternative as somebody suggested would be to buy another engine atogether, play and pray...
I dont think its a case of that really Alex, these engines are about as agricultural as bike engines get and the chances of one flying apart because it didn't have a few grams added or removed here and there are pretty slim!
I guess it would reduce the chances of a failure but by a very very small margin, I think as far as reliability goes, we are probably racing in one of the series with the least mechanical failures on record.
I dont know what the answer is, but it is nice that people are so meticulous about the preperation of their bikes. I agree with Kev in a big way about it being time on the bike that makes the biggest difference, but knowing that what you have under you is good also helps confidence.
Old 14-Jan-2009, 21:17   #52
Originally Posted by Matt-T28
Just to add my own thoughts on this subject,
David hasn't got anything in his engine that would not have come out of the factory in another bike on a different day of the week.
Its just that some engines are better than others as some will have fractionaly lighter parts, thats just the way it is. Its luck of the draw but all David has done is to turn his engine from a slower one with slightly heavier parts into one of the better engines.
I dont see the problem with that, as someone could go out tomorrow and buy an engine thats never been apart before that has a lighter crank than his but it would still be a standard engine.
But someone elses could have come out of the factory with poorer flowing heads due to factory tolerances, which wll cause the engine to run out of balance
So where does this line of acceptance get drawn ? is it when everybody can pay out to have there engine Blue printed to factory spec
As for reliability One blow up in 4 seasons under the No modification rule would suggest that as they come from the factory they are pretty reliable
Old 14-Jan-2009, 21:20   #53
vespa vespa is offline
Bikes: Super Twin 800; DD B; S2R 1000
vespa's Avatar
Mood: DD class B
for me personally the bottom line is that this year I just want concentrate on my riding and forget about mechanical issues and if balancing aids it I welcome it!
Old 14-Jan-2009, 21:22   #54
Matt-T28's Avatar
What engine rules are in place for Superstock racing?
Surely what we have is a similar kind of thing to that?
Old 14-Jan-2009, 21:34   #55
nogaromill998's Avatar
1.6.21 Crankshaft
No modifications are allowed (including polishing and lightening).
Thats what the rules say quite clearly. Where does it say that balancing is disallowed?
Old 14-Jan-2009, 21:35   #56
With regard to the crankshaft rule that we have had in the rule book for the 4 previous years, no doubt there are some out there that have already ignored that rule and had work done and got away with it. sadly thats human nature
BUT what is it that is now wrong with that rule.
Its very clear, its in black and white, easy to understand.
So why would we now need to change it.
Excuse 1 = Improve reliability = evidence already says they are reliable
Excuse 2 = Somebody may have a better one than me = and some probably haven't
Excuse 3 = Its good practice = only if the factory balancing is along way out and it costs just to find out
Excuse 4 = No Modification doesn't mean I can't modify it = says who
I'm sure if I read back through the topic I will come across a few more excuses
Old 14-Jan-2009, 21:38   #57
Originally Posted by nogaromill998
1.6.21 Crankshaft
just here
1.6 Machine Specifications
All items not mentioned in the following articles must remain as originally produced by Ducati on a 600 or 620 aircooled 2 valve model.
Old 14-Jan-2009, 21:42   #58
It ISNT modified......not in any way, how many more times Kev? And who are you or anyone else to determine someones right to do something within the rules that costs anything if they so choose? If someone wants to spend the money to make sure the engine is as well put together as it can be why cant they? It doesnt say ANYWHERE in the rules that there is a ceiling or a limit on what may/may not be spent on any one area of the bike build? if someone wants to spend £500 on a Nitron shock would you tell them it goes agains the spirit of DD ? Why not have a set of rules that says you can do NOTHING to a Class B bike save remove lights, stand etc, if you really are on a crusade to save other people's money for them? What happened to freedom of choice WITHIN THE RULES?
Old 14-Jan-2009, 21:44   #59
just here
It doesnt mention wheel balancing either. Is that also disallowed under the same blanket?
Old 14-Jan-2009, 21:53   #60
try reading the rules rather than making your own up
1.7.1 The following items MAY be altered or replaced from those fitted to the homologated motorcycle:
Any type of lubrication, brake or suspension fluid may be used.
Any type of spark plug.
Any inner tube (if fitted) or inflation valves may be used.
Wheel balance weights may be discarded, changed or added to.
If used Wheel balance weights must be suitably taped.
Gaskets and gasket materials.
Instrument and instrument bracket and associated cables.
Painted external surface finishes and decals.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:58.
