Old 16-Jan-2009, 23:04   #4
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Keith,
Avoid to fill up the tank above the MINIMA line.
Don't be scared to fill it 1 cm. below the line !!!
Check if the tank cap isn't obstructed . There's a hole on top for air pressure !!!
Check the rad cap as well, the internal spring must be free ...
Regarding the tank cracks, they often are located around the single nut incorporated into the plastic ...
Phil911
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:08.
