Old 21-Jan-2009, 00:00   #8
in that case I would wire it in on the earth side of a relay coil, so that when tilted the relay will drop out, I would then feed the power for either the fuel pump or Coils through the relay contacts so that when the relay drops out the feed is cut.
I would also fit an over ride toggle switch on the dash just in case
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:21.
