Old 21-Mar-2009, 17:33   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
sprocket nut
Hello
I need some help, in my stupid wisdom I forgot to loosen
the sprocket nut, any ideas of a way to undo it?
pic attached
TopiToo
Old 21-Mar-2009, 18:41   #2
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
You need a 12v impact driver. This will spin up and shock it enough to loosen it. Bought mine cheap from Aldi's great piece of kit.
Old 21-Mar-2009, 20:08   #3
Jasper Jasper is offline
Jasper's Avatar
Just take your socket with you to any tyre place and they can whizz it off.
Old 21-Mar-2009, 22:54   #4
Shandy
If you've got a rear wheel your not too worried about, stick that on the other side, clamp it in a workmate and then take the nut off, worked for mine
Cheers,
Shandy
Old 22-Mar-2009, 19:03   #5
Bikes: 748ish . .
Hello
all done thankyou,
air gun did the trick
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:36.
