Old 30-Mar-2009, 23:11   #61
andys 900ss's Avatar
Originally Posted by Rattler
I did get quite obsessed about reducing her weight its true. I was fortunate enough to be able to strip the bike right down and build her up from scratch and was able to remove anything that wasn't needed.
Some ideas:
- go through the bike and get rid of parts you don't need.
- Only use steel bolts if its load bearing otherwise use plastic bolts or cable ties.
- Do you need to fit washers? (these obviously spread the load in certain places), or can you just use loctite?
- use cable-ties to secure parts to frame (dump mounting brackets)
- Do you need a battery box?
- Do you need a rear hugger, a chain guard, plastic shields, etc?
- fit a steel tank
- Make sure you've got very light clipon bars
- Only fit a nose and belly fairing, and make those minimal
- don't fit crash bungs, what do you save?
- use really light faring brackets and make them as small as possible
- any bolt threads that go through a nut (and protrude through) are not needed - cut the ends off - loctite.
- dump the airfilter
For the seriously commited (all of us!!)
- get a 2-1 exhaust and get as much Ti in it as you can.
- use a 600SS frame (I didn't), these are the lightest frame eligible in DD.
- use a single disk/caliper
- make sure you just carry enough fuel to get through the race, measure and calibrate (but you do need 2ltrs at the end of the race for ACU rules though).
- get light leathers, helmet (X-lite?) etc...
- you could remove all paint from the wheels and frame too.... more weight to save!!
Finally, before you race, cut your nails, pluck your eyebrows, take a dump, blow your nose and have a w**k,
Enjoy.
Tim
You missed "GO ON A DIET", I'm still trying but love my food.
Andy
Old 30-Mar-2009, 23:21   #62
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
Tim you did gret job on yout old bike and its credit to you, Steve has a plastic tnk fitted at the moment (borrowed) as he couldn't get on with the taller SS Tank so it could have weighed less when you raced it.
As for the removal of paint from the fram, does sliding it along the track and into a gravel trap do a good job or would taking it to a proper sand blasting place be better
Every little helps!!! - but I missed a few tricks with not stripping the frame and wheels of paint though and many other ideas - I feel a book coming on!! If only I'd had another year!!
Old 30-Mar-2009, 23:25   #63
Originally Posted by DRR007
You can add mine to the list aswell kev. And anyone who can offer any advice to get mine down from 180kg to 150kg would be appreciated.
You get it to 150kg for Class B and we'll have to find you some lead, about 4kg worth.
My bike weighed 173kg but by laps 9 and 10 of the second race it felt alot more.
I already have an alloy arm to fit and will be looking at fitting some lighter silencers, would much prefer a good 2 into 1 but they cost.
A lot of weight can be removed without going mad on Titnium, etc.
Dallas's bike has a standard Steel SS swingarm and a standard tank,
I know I could shave a bit more weight off it without going for n Alloy arm, alloy tank or later typrrear wheel, but that would put it close to the 154kg limit at the end of a race with just 2 ltrs of fuel in it
Tomorrow I'm back at work and the spread sheet is on my office PC so I'll enter the details of those that have given the OK to do so and put it up.
Here's some food for thought
M620/M600(1999 -2001) forks and SS top yoke = 8.7kg
Ti race can = 1.5kg
early SS frame (standard) = 10.4kg
Alloy arm = 4.1kg (I think hat included the rear spindle)
Carbon Cans = 1.7kg ea
Link pipe for above 0.6kg
WP Emulsion shock = 2.6kg
later type rear wheel, disc & Diablo = 13.2kg
I'll way some other bits when I have some spare time
like standard SS bars, alloy clip-ons, fairng brackets etc
Old 30-Mar-2009, 23:47   #64
SixtyTwo SixtyTwo is offline
Bikes: Desmodue b, 1098s
you can add my bike to the list kev
Old 31-Mar-2009, 00:10   #65
Cheers Sam
and well ridden, I recall saying to you at the Prize Giving I expected you to get some trophies this year, nice of you to prove me right and to get Fastest lap as well - fantastic
Hope you get those forks sorted for Angelsey
Old 31-Mar-2009, 00:16   #66
Andy
As we could see when you hoped on the scales
Old 31-Mar-2009, 11:20   #67
Here is the spread sheet less those that haven't indicated to me that they are happy to have their info published on the site
editted to add AndyC's info
Old 31-Mar-2009, 13:32   #68
trouty trouty is offline
trouty's Avatar
Mood: i'm a grey dude...
would have been interesting to have anothwer column, with the riders weight also
Old 30-Apr-2009, 18:31   #69
rossco572 rossco572 is offline
rossco572's Avatar
Mood: elated
Thumbs down rider weight!!!
No thank you!! and i'm sure that the ladies amonst us would also like that kept a closely guarded secret!! To be divulged to only my doctor or undertaker whichever i meet first!!!!!
Old 30-Apr-2009, 18:43   #70
rossco572's Avatar
Mood: elated
As a result of winning the weigh in, my enforced weight loss programme for the bike has begun, off went the stock rear shock and on went the ohlins that was on my perfect keep forever 900ss called duchess, also her carbon SL seat unit. had to find stick on number boards for that as it has a wonderful Foggy #1 in carbon showing through the paint work and i don't want to damage that. I'm really fed up that i could not for the life of me, find anywhere that stocked Fablon in plain yellow. eventually got these motox ones from a place in portsmouth called dirtbikebitz.com
i've also attacked the bike with a drill in an effort to get of excess metalwork, i am using a few probolt bits as well. this weekend i am going to a mates in cowley who is a bit of a wizz with a welder and we will try and convert the pipes from 2-2, into something like ghost has on his bike, sorry phil hope you haven't patented the idea yet and cheers for the insiration.!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:55.
