Old 24-Apr-2009, 11:09   #6
DSC Member 916Neil 916Neil is offline
916Neil's Avatar
Mood: Waiting for summer
Bike been to Dyno Bike - Power commander fitted
An excellent afternoon at Dyno bike. Paul explained everything he was going to do then set to work. Did a base run and commented that should be able to save me lots of fuel. Mounted power commander on leading edge of air box just under the steering head. When doing the runs lots of big negative numbers at the bottom end where the power commander was leaning off the fueling. After set up gave me 3 to 4 bhp extra throughout the rev range - best peak was 134.75 BHP.
Bike to ride is now much sweeter and crisper. Mate who has ridden behind it before and after has commented that it sounds that way and also there is less of a smell of fuel. Hope to be out on it this weekend to see if the 80 miles to fuel light is improved as hoped.
Also did a run with baffles fitted afterwards. Cropped about 5bhp off throughout the rev range and made the fuelling slightly rich. Will run without unless Police or track day noise test dictates otherwise. Attatched graph from dyno.
Live each day as if it's your last - one day you will surely be right
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:38.
