Old 21-Jun-2009, 23:36   #1
where to get my suspension done?
staying with the rear for now, but need heavier spings in the frontg. Any reccomendations? prefer south of Birmingham so I can deliver and collect!!
Old 21-Jun-2009, 23:40   #2
WeeJohnyB's Avatar
Do a trackday with No Limits and get Colin at 100% Suspension to do it for you, then test it for 7 sessions whilst he adjusts as required...there is no better way to test it and get sound advice from a real professional.
Or, you don't need to do the trackday, just turn up at Brands or something and Colin will do it for you.
WeeJohnyB
Old 21-Jun-2009, 23:48   #3
need springs; max preload, and compression, and still bottoming out the forks at cadwell! Rick from JHP checked the front sag and it was spot on....just way too soft!! So 1.1kg springs for me
Old 22-Jun-2009, 00:04   #4
Gaz 748's Avatar
Steve Jordan in Bookham set mine up and he is an Ohlins dealer.
748R - Less is more !
Old 22-Jun-2009, 06:59   #5
Give K-Tech a ring, you will have them bu post next day.
http://www.k-tech.uk.com/
Old 22-Jun-2009, 21:22   #6
Dukey Dukey is offline
Bikes: 916
Dukey's Avatar
Mood: Love Europe.....Hate the EU
Steve Jordan has done a great job on mine too! Recommended & local-ish.
Old 23-Jun-2009, 00:34   #7
Pop along to Fair Oak and have a word with Gary Teague
http://www.garyteaguetuning.co.uk/main.htm
Old 23-Jun-2009, 10:54   #8
cheers Kev, nive and local and on my way to work (almost!)
thanks all for the replies
Old 23-Jun-2009, 11:19   #9
Gary was a front runner for many years in the North Glos race club and has a great test road outside his front door, just remember to slow down for the single lane hump back bridge
Old 23-Jun-2009, 19:10   #10
banoffee banoffee is offline
Mood: Running in 848
have had fork and shock rebuild work done at Steve Jordan and Setup Engineering. Both good but took a while.
Had the 848 setup for me (stock kit, just settings) when new by Rob @ Pro-Twins, did it while I waited
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:45.
