Old 05-Jul-2009, 14:07   #1
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
termi gaskets ??
termi is blowing at the first joint from the rear cylinder. popped over to jhp and got this
http://www.ducatisportingclub.com/at...d=12467989 41
the one jhp have supplied is way to big anyway
took the exhaust off this morning and none of the joints have a gasket of any sort.
http://www.ducatisportingclub.com/at...d=12467991 11
should they have a gasket ??
Old 05-Jul-2009, 14:39   #2
Yes all the joints should have a gasket, they are around £5 each, one large diameter and three the same smaller diameter.
Old 05-Jul-2009, 15:02   #3
Glyn's Avatar
thanks ghost
just to clarify this is the full 2 into 1 into2 54 mm system
Old 05-Jul-2009, 15:07   #4
My system is the asym one but a slip joint requires a seal regardless, or it will suck in air giving popping on the overrun and blow also.
Old 09-Jul-2009, 07:19   #5
Did you get it sorted mate?
Old 09-Jul-2009, 18:53   #6
Glyn's Avatar
yep all back together and no gaskets. just a bit of exhaust sealant.
Old 11-Jan-2010, 11:16   #7
matty matty is offline
my full system has no gaskets and no back firing???
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:47.
