Old 30-Aug-2009, 23:49   #1
Originally Posted by Ghost
But there could be the possibility of adding the brackets yourself. If the mono frame is strong enough to cope with a pillion.
Noooo!
The alloy mono subframe is very lightweight and made out of Swiss cheese.There have been loads of them snapping as mono's,so no way will it cope with a passenger weight.
The genuine mono seat unit will only fit the mono subframe.The bip subframe is a lot higher at the back.I have seen a few where the owner has sawn the rear subframe loop off but the mono seat still does'nt sit right.
Nah,swap subframes,its a dead easy swap and should'nt take any more than an hour with a tea break.
For bip owners wanting the mono look there are alternatives,... like a MotoGP inspired seat unit that bolts straight on,....or a clip on cover that goes in place of the pillion pad.
Old 31-Aug-2009, 00:14   #2
This was my DP seat unit and went straight onto my bip frame with no probs. I wasn't aware that the monos were all ally subframes.
Old 31-Aug-2009, 00:26   #3
AFAIK,all 749/999 monoposto's had an alloy subframe.
The pic of the 749 at the top of the page is'nt very clear,....I cant see the hole or bracket for the seat lock,suggesting its alloy,...but I guess it could be a bip subframe with all the brackets ground off.
Old 31-Aug-2009, 00:48   #4
I have all the bits he wants and if the subframe needs swapping then we can go that route also.
But then the BIG Question!!!!!!!!!!!!! Where do I put my tax disc.
Old 31-Aug-2009, 01:00   #5
Old 31-Aug-2009, 22:17   #6
Wes Wes is offline
Still happy to do a complete swap if you are.
Am aware you're in Pembray at the weekend. I'm in Cardiff if you're going that way or can sort something else out.
Will call in the week.
Cheers,
Wes
Old 31-Aug-2009, 22:44   #7
Cheers,
Wes
I'll be getting to Pembrey Fri evening and there till 17:00 on the Sat. I'm prepared to take my subframe off and bring it down with me. You will have to do something about the key lock tho' as I'm not giving you a key that fits my ignition.
Old 31-Aug-2009, 23:05   #8
You could get a plain one made with no ign chip,but just like the 748/9** series,you can pull the cable with yer finger to release the seat.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:55.
