Old 05-Sep-2009, 10:36   #2
That will be the EOBD warning light.Its telling you there is a fault somewhere.You can bring up the fault codes by holding down the l/h button on the clocks while you turn on the ign.Here's a list of fault codes;
http://www.ducatisti.co.uk/forum/duc...ror-codes.html
Probably not too much to worry about,.....it could be something simple like low battery on tickover,a badly adjusted clutch switch,or sometimes if you roll backwards slightly it can confuse the speed sensor.Other common faults are front coil shorting or fuel pump relay.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:22.
