Old 18-Sep-2009, 15:50   #2
injected injected is offline
Bikes: Multistraddle S, Cucciolo
injected's Avatar
Mood: Blown away!
Originally Posted by TopiToo
What I can not understand is there must of been some force behind the panels to blow them off the bike in such a way and do so much damage?
Is it possible for coolant pipes to expand like a balloon to eventually burst dumping coolant?
I suppose anything's possible, but at a pressure of say 6psi and a rate of flow that's relatively low, I would have said that fairing loss as a direct result of the hose failing was unlikely. Which Dzuses failed - the ones along the top of the side panel where it meets the nose?
I had a similar failure on my 748, and even with a full belly pan to catch all the water the only thing that happened was my rear tyre got wet.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:24.
