Old 29-Sep-2009, 09:38   #4
Originally Posted by chris.p
Possably starter motor solanoid, if you put a screwdriver over the terminals it should turn the bike over, if it does turn over it will be the solanoid that will need to be replaced.
Yep,and while you're at it,check the push on white connector as its pretty common for the pins to corrode and cause starting problems.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:35.
