Old 21-Apr-2011, 01:56   #1
Simps Simps is offline
Yes sir, quite right sir. Ive changed it here and above.
Old 21-Apr-2011, 08:23   #2
Jolley Jolley is offline
Bikes: 959
Jolley's Avatar
Cheers for that Hugh..... I am actually surprised to see I'm still joint 5th without dropping rounds.
Tonio, any chance of using this to update the results site? (here normally, for those new to the series: http://www.desmodue.co.uk/ ). Someone will have to sort out the Class A Results for you though.
Old 21-Apr-2011, 10:06   #3
Really?? With a win and a second
Old 21-Apr-2011, 11:45   #4
Bikes: 959
Jolley's Avatar
Anyone with a few decent results in the top 6 in theory should be ahead of me. I expected to be 7th+. Still, there is a long way to go yet!
Old 21-Apr-2011, 15:00   #5
As we all must drop a set of result you are still in joint 1st with Phil and Kev so its all good for you!
I am all good with 1st & 3rd, I would have preferred to have that 2nd at Mallory and be up there with you but Neil had other thoughts on the matter and dispatched me nicely just before the finish line. Have to admit that I now know what it must have felt like when I snuck by you at Brands!
Old 21-Apr-2011, 16:06   #6
c'mon, not really - look rate the rate the points drop off after the first 2....
Old 21-Apr-2011, 16:29   #7
badgerpilot's Avatar
Are the numbers in brackets race numbers?
If so quite few errors but nice one for doing the chart.
Scott (#50)
Scott #50
Old 21-Apr-2011, 17:45   #8
Scott (#50)
I copied Jolleys list on a previous post and I think these numbers were actually points not race numbers. I have deleted them all now because I cant be bothered to change everyones.
Old 21-Apr-2011, 16:35   #9
Bikes: 959
Jolley's Avatar
Well, if you want me to prove it is possible....
Taking no results from anyone above me:
If phil had even 1 point from Brands and you had Jimbos 3rd from Brands then I would be 7th. Simples!
Old 21-Apr-2011, 17:32   #10
if only
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:16.
