DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 27-Nov-2011, 17:07   #9
Should also mention the Injectors are different, both use 45mm throttle bodies but the 750 uses early type green injectors that flow 270cc/min where as the 620 uses the later Pico Brown Band injectors that flow 330cc/min.
Both use the same Throttle Position Switch and 3-Bar fuel pressure regulator.
Fitting a PC3 USB to either will allow you to fuel Map each cylinder independantly
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:13.
