Old 06-Jan-2012, 20:43   #7
007 007 is offline
Bikes: 996 Bip
007's Avatar
Mood: CITIUS EST MELIUS!
Originally Posted by KeefyB
The pin assembly is part of the lever and not available separately.AF1 racing in the USA sell spare pins,but they work out around £45 with the postage.
AFAIK,nobody in the UK sells them.Best bet is to buy a s/h lever and be careful removing the pin assembly.
Forgot to say,iirc,the pin has loctite on the threads.Once the grub screw has been loosened,the pin should come out by carefully turning it out of the front of the lever.(In other words,screw it in,....if that makes sense!)
Thanks indeed for your help Keefy, good to hear from you.
I'll have another go, as I've backed off the grub screw already.
Regards,
James
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
