Old 26-Mar-2012, 11:09   #1
pignog pignog is offline
Bikes: 996S Z900
Question 996S misfiring
Has my 996S for about 4 months now, and went on 3rd ride, it seems to cut out at around 7000 rpm in lower gears and around 9-10000rpm in higher gears.
Feels like a rev limiter, any ideas
It has Termis.
Old 26-Mar-2012, 11:35   #2
dunlop0_1's Avatar
I have recently had a similar issue. Have a read of my post and the link contained in it.
http://www.ducatisportingclub.com/sh...ad.php?t=85648
Old 27-Mar-2012, 22:34   #3
rogerreno rogerreno is offline
I had a similar occasional misfire under load and initially thought it was one of the coils was breaking down.
However, while I had it in bits recently to change the belts I decided to check the plugs (that I supplied to the garage to fit when I 1st bought it)
And guess what....I think thats all the did because I could have flown a Jumbo Jet through the gaps!!
So, set gaps to spec, refitted and went out for a ride, feels and pulls like a different bike now!!
Its worth a check, as if the plug gap is too big the spark can fail when under load..
Old 28-Mar-2012, 07:50   #4
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
From the title I thought it had been stolen.
Old 28-Mar-2012, 09:23   #5
Cobbett Cobbett is offline
Bikes: 750ss, 998s
Cobbett's Avatar
Exactly my reaction - almost a relief to see it only had a problem!
Old 28-Mar-2012, 10:19   #6
Bikes: 996S Z900
Thanks for that, I put missing to arouse attention!
I'll check the plug gaps, I don't think it is Dunlopo 1's problem as it starts and runs fine, it's just at higher rpm, and it sounds like a rev limiter or traction control! but isn't either of course.
Old 28-Mar-2012, 14:23   #7
Dirty fuel filter.
Old 16-Apr-2012, 15:51   #8
Bikes: 996S Z900
Replaced plugs and fuel filter, which was filthy, and now it revs through
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:43.
