Old 18-Apr-2012, 18:52   #1
welsh999 welsh999 is offline
999 new clutch
After some help.
Put new clutch plates in as last set worn, clutch works ok but clutch is dragging when pulled in.If i put the rear brake on whilst on padock stands wheel stops as expected and the cluch stops spinning, engine ticks over fine.Was also tricky to get into neutral with engine running but bleeding the master cylinder sorted this. Will the clutch bed in or have i missed something.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
