Old 09-Jun-2012, 07:16   #3
kellybuilders@bigpond.com kellybuilders@bigpond.com is offline
Newbie
Originally Posted by PDL
A lad on the TDR site is looking at a 996 SPS
"I've been wanting something a bit special for a while now
I've found an sps 996 that ticks all the boxes for me
Is there anything I should check on this version ?
Anyone have any experience of one ?
It's a road bike and I won't be tracking it - I want one as a bit of garage eye candy
Couldn't afford one back in 2001 and I still can't now - but hey you only live once
Thanks "
Can anyone offer anypointers?
Regards
Hi Paul. i have a 996 sps. Its quite an amazing bike when its going well. Not the best bike for general road use. Mine has played up a bit but when ridden hard on the track it goes great. I would segest you read up about the sequential injector set up they have and the P8 ecu. A few guys have had heaps of dramas tuning this bike and end up disconnecting the second injectors. Mine coughs and splutters under 5000 rpm unless under load. As soon as i get up it ,the thing is an absolute beast. I have friends with s4r monsters and my 12 yr old sps simply blows them away. They have dyno tuned ,changed eprom chips and pipes , gearing ect. and they still cant believe it when we hit the main straight at lakeside i just fly by. So , yep , an SPS is a lot of bike to handle and is made for track work. Look under the seat and make sure it is running a 1AW 1.8 p8 ecu. Check for water leaks around the cooling tank on the right handle bar side, take off the side covers (30 seconds) and check to see if it been dropped. eg. bark off the cases. Make sure it has no problems starting and idling perfectly. Dont be too concerned if it seems pretty jumpy and rough at low speeds. They are all the same, unless the eprom chip has been changed and the sequential injectors disconnected.
good luck.
ned.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:13.
