Old 18-Jul-2004, 16:48   #5
keefer keefer is offline
keefer's Avatar
that is prob the cheapest way to do it, put some in line on the fuel pipes. i have seen the connectors you mentioned and they look very similar. only the factory one's fit into the pump base. but as mentioned above you would need a second hand base as the bore is larger. id put them in the fuel line easiest way to do it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:24.
