Old 22-Nov-2012, 20:02   #6
Originally Posted by brummydave
Ialso found a tacho,virgin ecu and keys for £250 on flea bay .
Thats Cheaper than my set on there, Derek at Duchamducs had a 800 see on there that had a starting issue.
But you only need a ECU with the IMMO off so no more than £120
Making a loom from scratch would cost far to much as the ECU connectors alone cost £89 for the pair, cheaper to but the right loom or modify something like a 998 one.
I'm currently working on stripping down the loom for Chris Clarkes Class A bike, for which I also supplied the Engine, ECU, Sensors,TBs, Injectors, Pressure regulator and 3-bar fuel pump
MAP/Air Tem sensors can be had for £20, and less for the Engine Temp sesnor which iirc is a WTS09
As you say Dave most 3 phase reg/recs whould work, as should most coild of the same impeadance
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:54.
