Old 08-Jan-2013, 17:48   #1
Mr.Number Mr.Number is offline
Bike prep
...Guys, trying my best to add to the numbers and get on the grid for March class a, have a standard monster 620s ie lined up and hopefully sale will go through late January.
Checking skids posts, registration looks straight forward and should be able to complete that process before kick off.
Question is, and I know if I looked hard enough through the various posts id probably find the answers but to summarise, what are the essential changes, apart from the obvious race faring, that need to be made for the bike to be reasonably competitive ?
I also want to get an exhaust fabricated for the bike, just one exit instead of the two that come on the bike. Any recommended fabricators around the liverpool / manchester areas ?
Regards
Kev
Old 08-Jan-2013, 22:16   #2
Along with the fairing You will need to lockwire the sump plug, oil filter (use a large Jubilee clip or a K&N filter) Oil Filler and the Oil Filter cap on the right side of the engine just below the clutch cover.
A Oil containment Belly pan to ACU spec will be required, bar ends require spherical bungs.
On a Monster raising the pipes and footrests for better ground clearance would be a good idea.
That covers the basics to get it out on the track, to make it more competitive, loosing some weight off it and the brakes can be improved as can the suspension.
As for the engine I would suggest getting the cams dialled in and getting the fueling sorted
Old 09-Jan-2013, 07:25   #3
bally71's Avatar
Mood: Inquisitive cat
JAC are in nottingham .. made me a 2 into 1 underseat
bit of a treck but well worth it .. 250 notes .. top job
mates the original headers with the end can of your choice
just keep the overall pipe length the same and you shouldn't have any probs
and yeah .. power commander and dyno a must
apart from that as long as you can ride it fast enough you'll be there or there abouts
Old 13-Jan-2013, 07:22   #4
What's size sump plug thread on the 620, il get a pre drilled plug
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:27.
