Old 19-Jan-2013, 14:47   #8
Originally Posted by dunlop0_1
If memory serves Simon I think the same belts fit the 620 and later 600 & 750.
Yep they are same width and same amount of teeth. The later belts as listed for the 620 cost about another £20 and from what I once read this is because they have a new formula in their make-up that reduces the the adhesion level between the belt and the pulley.
In some cases Ducati belts are on there third generation as they have been improved over time, but that doesn't mean you can't use earlier version apart from the Non Kevlar ones they did for the 916 etc with the white writing on them
And I would advise against using the square tooth belts on pulleys designed for belts with round teeth,
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:13.
