Old 26-Jan-2013, 23:30
Cam belt Tension
Hi there. Just setting the tension on my new belts on the 620ie. I'm using the Allen key method. 5 mm for the horizontal and the same for the vertical. I've heard people using 6 mm instead. What's the path of the righteous?!
Old 27-Jan-2013, 00:00
As the rear usually runs hotter they recommend setting the Vertical cylinder belt tension with a little less tension than the Front Horizontal cylinder.
I set the Vertical 15Hz less than the Horizontal
Old 27-Jan-2013, 00:01
The point of using 6mm on the vertical is because it gets less airflow than the horizontal and runs hotter. This means it expands more, so the "running tension" will be greater than the horiz cylinder.
Old 27-Jan-2013, 00:03
Kev beat me to it!
Old 27-Jan-2013, 00:11
Si1208's Avatar
Si1208 Si1208 is offline
Bikes: Ducati Multistrada 1200S Touring, Honda CBR1100XX Superblackbird (at least it's a red one!)
Mood: Happy new owner of a Mutley !
So what frequencies do you use? I use the sonic method on my 996 belts, but haven't tried it for the DD because I couldn't find the frequencies to use.
Old 27-Jan-2013, 00:44
2v (Non DS) 145Hz for the Vertical and 160Hz for the Horizontal
Old 27-Jan-2013, 08:18
Si1208's Avatar
Nice one - thanks!
Old 27-Jan-2013, 09:43
Originally Posted by Si1208
Nice one - thanks!
No problem Simon, figures were sent to me by Gates
Old 27-Jan-2013, 20:11
banger san's Avatar
Do you check it with a sonic screwdriver
Old 27-Jan-2013, 21:09
Well I used a 5 mm on the horizontal and a six on the vertical. Making sure it fits through snugly but a 6 and 7mm doesn't
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:08.
