Old 31-Jan-2013, 16:17   #10
mark 999 mark 999 is offline
Bikes: Anyones
mark 999's Avatar
Originally Posted by yendor
The pressure going in to the cooler will be much less than 80psi due to an open return back to the crankcase, and crankcase is not under pressure, if it was it would blow a seal, hence the breather at the rear.hope this helps
That does it for me, thank you.
That is most certainly the sort of "lay mans terms" I understand !
Also, cheers to Kev (again) for the input, I'll let you know on the costs, etc once I've spoken to him.
Cheers fella's.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:03.
