Old 15-Aug-2004, 22:20   #3
Originally posted by logyk
On checking the battery on my 999r today prior to its removal and replacement under warranty I discovered that the wiring for the left fan had been dragged into the fan. The bades of the fan are damaged and the wiring was almost severed .......bare wires visible ....some threads cut, others intact !
Clearly this would not be the best thing to happen to anyone whilst out on a long run on a very hot day !!!
Please check yours.
Thanks for the info mate.I'll check mine in the morning.
On the subject of wiring,the bullet connectors for the brake/clutch lever switch wiring are fixed to the frame where they get all the wet and road muck.The connectors corrode and your brake light stops working.My clutch lever switch connectors corroded witch meant I cant start the engine in gear,even with the clutch in.A pain when the engine cuts out in traffic.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:49.
