Old 04-Aug-2013, 11:15   #1
bally71's Avatar
Mood: Inquisitive cat
Originally Posted by mat2hew
as you know, I've got Deans old Maxton shock which is 5mm longer than standard with another 15mm of adjustment, I have tested it on a track day and now have it wound it fully out, this has raised the rear by 28mm at the seat, I have also raised the front by 10mm for more ground clearance.
I find that I now feel much more in touch with the front tyre, I can push more weight onto the front in corners allowing me to keep a higher mid corner speed, beforehand I felt that the front tyre was on the limit of grip and all the weight was sat back on the rear, which pushes you wide mid corner making you throttle off to pull it back in.
that's about where I'm at at the moment.
I'm still not sure why I'm so slow at the moment but I'm hoping that this will have helped.
Thats pretty extreme
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:02.
