Old 25-Aug-2004, 21:53   #2
Nope,thats it.If the new plate does'nt come with a bearing,you may need to press out the origional one.
One more thing,the standard pressure plate has an arrow stamped on it wich lines up with a groove cut into one of the fixing posts.This is to make sure the plate does'nt foul on the inner drum.Some replacement plates dont have this arrow,(Some have a dot punched mark)so double check the clutch operation before you put it all back together.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:12.
