Old 22-Sep-2004, 18:09   #1
Mr_S Mr_S is offline
identifying heads (S or R..)
Is there an easy way to identify what type of head is fitted to an engine?
I've got a set of low mileage 2002 heads that cost me less than the price of a pair of rockers, and I want to know how to check if they're S or R heads?
I know they're not E's as they don't have the "step".
But
are the stamp marks on the top significant?
Do I whip out the vernier and measure the valves?
Can I check the cam without taking it out???
Jason
Old 22-Sep-2004, 18:24   #2
keefer keefer is offline
keefer's Avatar
I think the cams will be marked up ?
Old 22-Sep-2004, 19:15   #3
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
R u talking tessi heads? if so they are both the same except the R head was sand cast and the S head cast in a different way due to mass production. That is with the 998S / 996R
Don't know about the 998R
[Edited on 22-9-2004 by Jon]
Old 22-Sep-2004, 20:13   #4
With you mentioning E, I guess you're talking 748??
The R heads have 36mm/30mm valves and the pulleys are wider (thicker belts).
The valve lift will also be about 1mm higher on both inlet/exhaust.
After that, you need to pull the cams and check those.
Old 22-Sep-2004, 22:34   #5
Cheers nelly, yep 748 heads (should have said), and I'll get a vernier on the valve heads tomorrow.
Bargain of the season if it's a pair of R's.....
Old 23-Sep-2004, 10:44   #6
If you do fit them, watch the pulley width and alignment. They are different. You'll need the wider pulleys for the lower twin set, and spacers etc to get the alignment correct.
Saying that, you should be able to use your existing pulleys.
Just bear in mind that whichever route you take, "something" will have to be changed.
Old 23-Sep-2004, 15:00   #7
They're S heads
Oh well, they were still a bargain and with 12K less use than my current ones....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:54.
