Old 11-Jul-2014, 11:27   #10
Originally Posted by chris.p
I think Kev means remove the Sprocket cover, not the Clutch cover
No I don't Chris as the only way to be certain is to remove the clutch cover you can then count the teeth on both the primary gear and the clutch basket 32/73 respectively for the 2.28 to 1 and 31/62 for the 2 to 1 ratio
The output shaft is a good guide but there is nothing to stop someone having changed the primary gearing on a previous occasion
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:45.
