DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 06-Dec-2014, 14:48   #1
Ohlins DU807 Shock for Sale 851/888/M600/750/900
Ohlins DU807 Shock to fit Ducati 851 and 888 Models
Should also fit Early Monsters with suspension hoop on the swing arm Such as Class B Monster 600s and also M750 and M900 models
Only difference I understand is the length of the hose to the remote oil and gas reservoir/compression adjuster
Damping is good and all adjusters work
It has been Rebuilt in recent times (not sure exactly when) and at the time it has had a new bump stop rubber fitted
330mm Between mounting centres Eye to Eye
Fitted with a 650lb/in Spring which according to the info I have is for a rider weighing between 175 - 185 lb (12 - 13 Stone)
Tech Spec and Set-up data
Total length 330mm
Damper rod diameter 16mm
Width of fitting eyes 22.5mm
Stroke 65mm
Preload spring 14mm
Rebound adjustment 15
Compression adjustment 14
£325 plus postage at cost
skidlids@ntlworld.com
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:54.
