Old 03-Feb-2015, 17:47   #1
dave998 dave998 is offline
1199 Panigale Side stand switch
Hi all especially Nelly!
Anyone know which of the three wires on the side stand switch I join together to by pass it?
There's Brown/Violet
Orange
Black
Also removing the rear light unit to fit a race unit,how do you get round the error code flagging up on dash? because it can't detect the light anymore.
Old 23-Aug-2015, 13:42   #2
STEVENSON-KAATSCH STEVENSON-KAATSCH is offline
Newbie
...as far as the tail-light goes...
Ducati uses something called a CanBus wiring system. Put simply, every sensor output and command input goes through the Electronic Control Unit (ECU), and as such, any deviation from an expected response from the tail end of your bike, such as unplugging the tail lights, will make it shout 'foul' ! Just as in the LPG conversion industry, where petrol engines are persuaded to run on Liquid Petrolium Gas, one has to disconnect the petrol injectors without letting the ECU know we have done so. The answer is to fit an 'Emulator', to reproduce the same electrical response petrol injectors have and put the gaseous substitute into the air flow instead. Ignoring the gas, as it is irrelevant to this matter, the Emulator is simply a group of resistors, one per injector, which gives the ECU the answer it is expecting for every electrical squirt of current given out. It expects a certain electrical resistance and it gets it. The Ducati ECU needs a similar thing as a surrogate tail lamp. Measure the electrical resistance of your tail lamp.... it might even be written on it or specified in some of Ducati's literature and get a suitable resistor from your friendly local supplier or the Internet. Then get some suitable electrical connectors (needn't be the whole plastic plug) and make up the connections. Remember to insulate everything... heat shrink is a good product for this.
Old 23-Aug-2015, 13:49   #3
Newbie
....side-stand switch....
....just looked at the first bit of the question. No need to be sophisticated, just remove the switch unit from the side stand after determining where 'off' is (when the stand is up) and glue/cable-tie/sticky-tape it in position, then cable-tie the loose wires away from moving or hot things. Job done.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:28.
