Old 02-Feb-2005, 19:37   #1
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
it's clutch in! blip ! down shift ! clutch out !
the reason we did it, was if you have ever driven an old HGV with a "crash " gear box , The blip of the throttle. A. brings up engine speed with the gear box speed Thus negating the shift!
road speed can alter this so if you get it all syncronized you can actualy down shift without using the clutch!!!!
Old 02-Feb-2005, 19:38   #2
Originally posted by NBs996
Originally posted by tp-996
Keep throttle pinned, give the quickshifter a nudge, Roberts your mothers brother.
Now, where's a quickshifter catalog ...
on a downshift tony? Are you sure about that me old aussie fruit?
What are you changing down for? I want go faster, not slower!!
Old 02-Feb-2005, 19:44   #3
Bikes: 1098
madmav's Avatar
Mood: Chilled
Tp that was known as "Double De Clutch" still used today on some big trucks!
but most are no syncro boxes
Old 02-Feb-2005, 19:45   #4
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
not sure what the proper reason for it is, but i do it to stop the back wheel working too hard against the engine. It can be good fun when you're playing about on the track getting the back to drift sideways into a corner but when I'm hard on the brakes in a straight line i'd rather not encourage the tyre to loose tractiona and waggle about!
Very tricky going down the box without the clutch... something i don't care to get to grips with, it just seems a bit abbusive!
Old 02-Feb-2005, 19:47   #5
NBs996's Avatar
save me a spot in the gravel trap matey!!
Old 02-Feb-2005, 19:49   #6
I drove that old Mack truck around on exercise for about two weeks, I had a left leg like the Governor of California after that!
Old 02-Feb-2005, 19:50   #7
I was planning on using you as the brake/block pass object mate.
Nothing personal you understand ...
[Edited on 2-2-2005 by tp-996]
Old 02-Feb-2005, 19:50   #8
Bikes: 1098
madmav's Avatar
Mood: Chilled
A quickshifter aint realy rocket science!
it just cuts the ignition milli second and unloads drive thus negating the gear !
set up is very important thou as not to blow gear box to bits
Old 02-Feb-2005, 20:16   #9
Bill O Bill O is offline
When I go Clutch in, Blip, gear down, its so smooth but "Twist of the Wrist" says the bit about engine speed and recomends Clutch in, gear down, blip, clutch out......when I do this it no so smooth.
Old 02-Feb-2005, 20:31   #10
Bikes: 1098
madmav's Avatar
Mood: Chilled
Thanks Bill O !!!
I rest my case
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:37.
