Old 14-Sep-2004, 14:44   #11
Spinoli Spinoli is offline
Thanks for all the interest.
Remedial action taken -
a) 3 x 1.5mm driven plates ordered from JHP to enable fine tuning of the stacking (about £4 each).
b) last friction plate temporarily replaced with 2mm steel driven plate. I figured out how a friction plate as the last plate would munch into the pressure plate - Doh!
c) Will order aluminium sintered plates to replace the standard Ducati ones (about £125 from JHP).
For info - I originally installed the kit into my old 996S, where it performed perfectly for about 2K miles.
When I got the 998, I took the kit out of the 996S and swapped it over.
Both times I was operating from exploded diagramms off the net - no instructions were supplied with the kit.
I remember having trouble getting the engagement point right on the 998, which is probably how I ended up with 2mm over on the stack height.
I have learnt better now.
Does anyone know if alternative clutch baskets (stronger than cheese) can be used with this slipper clutch kit?
Spinoli
PS: Don't get me started on black clutch fluid!
Old 14-Sep-2004, 21:27   #12
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Even DP do I think 3 types of ergal baskets. Higher the cost the better the ergal.
Old 14-Sep-2004, 22:51   #13
Is this any help?
http://www.tss.cz/hl_strana1.htm
Old 14-Sep-2004, 23:03   #14
ziggi ziggi is offline
ziggi's Avatar
@ Antonye
8K out of a clutch basket is good I'd say particularly for what it essentially a race item.
Old 14-Sep-2004, 23:56   #15
Ooops! Sorry, wrong link!
Goto http://www.tss.cz/
Then click: Racing Parts > Ducati/MV > Clutches > Antihopping
Then click the installation instructions at the bottom of the page!
Old 15-Sep-2004, 09:49   #16
Hi Antonye,
Having a spot of bother getting to the instructions on the TSS website, it goes to a clear red page with errors on.
Spinoli
Old 15-Sep-2004, 10:55   #17
Try this - should open in IE and allow you to click through the images to larger versions...
Old 15-Sep-2004, 11:05   #18
Here's a pdf version if the other doesn't work...
Old 15-Sep-2004, 15:38   #19
Success!!
Thanks Antonye.
Most helpful.
Spinoli
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:51.
