Old 02-Jul-2012, 23:18   #11
And to replace the gear selector its handy to have a Alternator holding tool, a 30mm Socket and a Torque Wrench capable of going up to 190nM
Old 03-Jul-2012, 05:25   #12
Brian while you had it apart did you check it was all centred OK as there are two points of adjustment
Usually the cause, incorrect adjustment. Also tight linkage and splinted lever position.
Old 03-Jul-2012, 10:40   #13
dunlop0_1's Avatar
I'd see a doctor about that Phil.
Old 03-Jul-2012, 15:28   #14
Bloody Blackberry and fit fangers. Splined lever. Lol
Old 04-Jul-2012, 22:50   #15
batesy2 batesy2 is offline
Bikes: ducati 620ss racer,aprilia rsvr mille,husqavarna 125 crosser
Mood: easy going,love to laugh,fairly competetive
No i didnt. so il whip it off again just to check,I have a Haynes,Will the method be detailed in there?
Again thanks for your help Kev.
Old 04-Jul-2012, 23:18   #16
Yes Brian the Haynes manual covers it quite well, nice pic of centreing using a ruler and the use of scribed lines to check up and down movement is equal
Old 17-Sep-2012, 12:17   #17
Spjallen Spjallen is offline
Think I might be having a do with this too. Bugger.
Old 18-Sep-2012, 00:41   #18
Originally Posted by Spjallen
Think I might be having a do wit this too. Bugger.
Well worth getting the problem sorted, it certainly improved my lap times once I got it fixed
Old 20-Dec-2012, 09:34   #19
Do you have to take the clutch out too? The Haynes manual suggests that.
Old 20-Dec-2012, 10:33   #20
Not for the Part I changed, just the left hand engine casing and the Alternator
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:59.
