Old 12-Jan-2005, 15:44   #11
DSC Member antonye antonye is online now
1. Switch engine off & remove keys
2. Lift up seat unit
3. Cut around the "do not remove sticker" where the round lump is
4. Prise out round bung that you just cut round
5. Identify fuel chip in the socket and note which way round it goes (should be a "notch" in one end)
6. Remove chip carefully and level to avoid bending pins
7. Insert new chip carefully ensuring all chip legs locate into socket
8. Push chip firmly home into socket
9. Replace bung
10. Put new sticker on top
11. Put seat unit down
12. Take keys out of pocket and test!
Old 12-Jan-2005, 15:46   #12
Here's a couple of pics...
an example replacement chip:
http://www.jimmy540i.com/ducatichip.jpg
the right-hand side shows the chip located in the ECU:
http://www.jimmy540i.com/ducatichip2.jpg
Old 12-Jan-2005, 16:04   #13
Frank Frank is offline
Mood: got to be a worry.....!
As ever on this site an answer from the top draw,
many thanks.
Old 12-Jan-2005, 18:00   #14
MarkyMark76 MarkyMark76 is offline
Mood: .
If it's like mine was, you'll spend half an hour trying to get the plastic rubbery muck off the chip that is in there at the moment to get it out.
If you have hands like a girl it might take less time!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:38.
