Old 24-Jan-2005, 12:43   #11
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
here's another
Old 24-Jan-2005, 12:46   #12
dave996's Avatar
Mood: Fed up...
There is no oil coming out of it, it you look at the last pic , in the middle of the pic it is also starting to lift.
Old 24-Jan-2005, 12:49   #13
keefer keefer is offline
keefer's Avatar
doesn't look good.
id want to drop that leg out and have a good look at it.
it doesn't look like plating just lifting.
Old 24-Jan-2005, 12:54   #14
dave996's Avatar
Mood: Fed up...
Unfortunately I don't have the means to drop out the fork and as I've never done it before I would be sh*t scared of damaging something else.
Knowing my luck at the moment I would!!!
Old 24-Jan-2005, 13:00   #15
keefer's Avatar
best take it back to the shop then.
but got a feeling they will say its impact damage i.e stone or road debris.
don't know till you try though
Old 24-Jan-2005, 13:03   #16
dave996's Avatar
Mood: Fed up...
Just sent a pic of to OYB. They don't think ducati will do anything with that as it is out of warranty but will get back to me on that one.
Old 24-Jan-2005, 13:04   #17
Felix Felix is offline
Certainly looks like you'll want to get the fork leg replaced. If you don't have the means to do it yourself (or a mate) then best take it to a shop. It's an easy job, should take more than 1 hour if you're replacing the complete fork leg. As already mentioned, the stock Showas pop up on Ebay quite often. Have a browse, but get it sorted.
Old 24-Jan-2005, 13:08   #18
Walenut Walenut is offline
Mood: Erratic
That’s odd it would take some force to do that damage at that point, so it could be a manufacturing defect but I wouldn’t imagine Ducati letting something as obvious as that through quality control. Has the bike got any other signs of damage have a look at the stops on the bottom yoke and front of the headstock at the bottom to see if they are still there or have been damaged. I wonder if it’s had a chain or something around the wheel and been driven off?
Old 24-Jan-2005, 13:13   #19
dave996's Avatar
Mood: Fed up...
I don't think it can be debris from the road as that part of the fork is protested by the mudguard...I could be wrong
Old 24-Jan-2005, 13:18   #20
keefer's Avatar
someone said earlier it may have been done by some ham fisted whatsit changing a seal or something.
otherwise what force made them come open ?
but your right about the mudguard protecting that part.
VERY STRANGE
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:18.
